However, having the bookmark window default to the foreground keeps the application running, which creates some keyboard shortcut conflicts.
Is there any chance I can revert to the old mode where I could quit the Hookmark app and have the Menu Bar Icon function in the background? Currently, the Menu Bar Icon quits when I close the Hookmark app.
Thank you, Luc, for pointing it out. I was able to resolve my issue without reverting to background mode. I hope to figure out how to leverage the bookmarking feature and integrate it into my workflow.
super! One way is to take advantage of the Bookmarks window menu. It’s easier to access the Settings from there than the gear button, though I use ⌘, for that.
And you can alt-tab to access the Bookmarks window.
as someone who is using a combination of Hookmark and Alfred to navigate between lots of files and items, I think that I’ve found a feature that could actually be very useful: In Alfred, when a file is selected, by pressing the right arrow key, it is possible to invoke a “Open with…” window. From there, it is very easy to select the app with which to open the selected file. I have attached two screenshots to illustrate this feature. I think it would be great it would be possible to open a file in the Hookmark window in different apps.
Hope you find this to be a useful feature as well!
