Deep linking to specific rows of an OmniOutliner document
Here is the previous “Get Address” script, which does not yield deep links.
use framework "Foundation"
tell application id "com.omnigroup.OmniOutliner5"
	set f to file of front document
	set p to POSIX path of f
	if (package folder of (info for p) is true) and (character -1 of p is "/") then
		-- package, chomp trailing '/'
		set p to (characters 1 through -2 of p) as string
	set rawUrl to NSURL's fileURLWithPath:p
	set p to rawUrl's absoluteString
	set filepath to (p as string)
	return filepath
Sorry for the delay in acknowledging and responding to your feedback. All very helpful.
The new deep-linking feature is great!
I know this thread is some years old but I was wondering if I could use the previous script also for OmniOutliner 6 without any issues (with changing tell application id “com.omnigroup.OmniOutliner5” to com.omnigroup.OmniOutliner6 of course) or if there is a newer script to just copy the file link instead of the deep link?
I have found it is more reliable to simply select the line you want in OO. Choose “Copy Omni Link” from the Edit menu. And then hook to that copied link with Hookmark.
Hookmark comes with an OmniOutliner 6 script. I use it multiple times a day. You might need to update to the latest version of Hookmark to get the latest script.
I am sorry, I wasn’t clear enough. I was referring to the “Previous script” mentioned above that has the Get Adress section getting the link to the file itself instead of the deep link. I tried it myself and just changed the 5 to 6 in the script. So far No issues.
I see. . Thanks for clarifying. We have considered providing two commands, one to get a deep link the other to get a link to the file itself. But we have held off in order to keep the UI as simple as possible. There’s already a lot of commands in the UI. We’ve had to put some in the Advanced menu.
