Sweet, thanks for the update!
unfortunately, that’s now looking unlikely. I’ll keep you posted.
Any update here? Just checking before I revert my Drafts scripts…
Testing is in the works and hopefully released this evening or Wed morn.
Sorry, but we have more delays with 2.2.1 … can’t provide a more specific ETA than ASAP , unfortunately.
No worries, we can wait! It’ll be worth it too.
Hook version 2.2.1 is now available . This includes ability to put x-callback-url in Get Address, which is illustrated in Using Hook with Drafts.
set callbackURL to "hook://x-callback-url/setCurrentNode"
set myURL to "drafts://x-callback-url/getCurrentDraft?" & "&x-success=" & callbackURL
set myScript to "open '" & myURL & "'"
do shell script myScript
return callbackURL
In our testing, the above Drafts “Get Address” script works in Big Sur but not in macOS 10.14, so we didn’t make it the default integration with Drafts. I don’t know if that’s a Drafts issue or a Hook issue — we’ll need to look into it.
Hi again, in case you haven’t seen it, Hook version 2.2.1 is now available - Releases - Hook Productivity Forum. I hope this helps.
Just found it! Trying it all now!
Edit: OMG SO SO SO MUCH BETTER for Drafts. It’s lightning fast. There really is no comparison between the UI scripting and native linking capabilities.
what version of macOS are you using? We haven’t tested that script on macOS 10.15 yet. I’ll propose to the team here that we update the script to make it conditional: if Big Sur, use x-callback-url, otherwise, use UI scripting; then we would release the update on Integration server so people can automatically get it.
Big Sur. It does seem to work, for what it’s worth!
Hook integration scripts v. 156 now available — Improved linking of Drafts app documents - Releases - Hook Productivity Forum. The script Hook uses to Get Address in Drafts now in case of Big Sur now uses x-callback-url
Hi - Auto update of this does not seem to be working at present
Thanks for mentioning. Never a dull moment. I’ve unlisted the linked topic until that gets sorted in the Pacific morning.
Any update here? I need to fix the Drafts script as I just messaged you privately about.
Version 156 is not available publicly yet after all due. Users on Big Sur who want the x-callback-url version can still get it from: Using Hook with Drafts – Hook. The latter doesn’t do a conditional (version) check, that’s all. I.e., it’s only for Big Sur users.
What is the status of using Hook with Craft?
My understanding is that x-callback-url support will be in Craft soon. When that is done, we and others can create integration scripts for it — compatible with Hook 2.2.1.
If Craft users would let us know here, we’ll be able to respond more promptly to the issue.
The following script will work with the next version of Craft (coming Mon/Tue) next week
set callbackURL to “hook://x-callback-url/setCurrentNode”
set myURL to “craftdocs://x-callback-url/getCurrentPageInfo?” & “&x-success=” & callbackURL
set myScript to “open '” & myURL & “’”
return callbackURL
Also @Luc - Do you have an example for x-callback-url for the “New Item”
In the meanwhile, for basic Markdown Links, the Keyboard Maestro Copy as Markdown Link supports Craft.
