Hello,
Hookmark (Setapp, Version 4.0.1 (5010; Integration v. 249)) no longer works with Mail (Version 16.0 (3731.300.101.1.3)…
I get the message : “No linkable item found in Mail.”
I restarted mail, hook, the Mac (Apple M1 Ultra), without success. Mail is checked in: System Preferences ->Security&Privacy->Privacy->Automation
Finally, if I use the the Mail “get address” script directly from Hook’s Scripts tab, the result is empty.
Thanks for your help and Happy New Year!
Éric Boissicat
Hello,
Curiously, everything works now after a shutdown and a restart…
Maybe it will help…
It sounds like your Mac had a hick-up. I’m glad it is resolved.
