It would be extremely helpful if Hook allowed user to send a linked item to LaunchBar, especially linked folders. For example, I am working on a Word document. Using Hook, I link it to a folder of “Research” documents. When I invoke Hook while Word doc is at front, I can see the “Research” folder there. As a long-time LB user, my instinct is to select that item and then right arrow into the contents of the folder, i.e., to select a document from that folder. Assuming you wouldn’t want to build that kind of complex functionality directly into Hook (maybe you would, IDK), it would be nice to be able to send the “Research” folder to LB, where it could be acted upon in that way.
