I’m having an issue with NotePlan: whenever I link (or hook) a note to another document, the link always takes me to a blank page when I try to open it in NotePlan. In other words, I’m unable to properly link notes or documents at all. Even if I don’t move the original note in NotePlan, the link generated doesn’t seem to work.
I evaluted a document this was breaking on and compared the URL generated by NotePlan:
noteplan://x-callback-url/openNote?filename=40-49%20work%2FAY25%2FAY25%20Fall%20SIPA%2Fassignments%20%26%20assessments%2FSIPA%20reflection%201.md
and for the same document by Hookmark
noteplan://x-callback-url/openNote?fileName=40-49%20work/AY25/AY25%20Fall%20SIPA/assignments%20&%20assessments/SIPA%20reflection%201.md
and I can see they are different. The NotePlan one seems to generate %2F for folders and a %26 for an ampersand. Barring renaming/restructuring my documents, is there a way to fix this on the Hookmark side? Haven’t encountered this with other apps in conjunction with Hookmark, so any solutions would be welcome. Thanks.
