Is there a way for Hook to link to a Folder in Keep It!? Reinvented Software - Keep It for Mac
Are you getting No linkable item found in Keep It
when you select a folder, but not when you select a regular file?
No. When I attempt to Hook a folder in Keep It I end up Hooking a file in the folder instead.
