Tried copying the same URL schemes from Firefox but it did not work for me.
EDIT:
Managed to concoct a working “Get Address” script for Waterfox.
Although the integration shows a strange behavior. Every time “Get Address” it’s called, it expands the address bar tile menu.
use framework "AppKit"
-- classes, constants, and enums used
property NSShiftKeyMask : a reference to 131072
property NSAlternateKeyMask : a reference to 524288
property NSControlKeyMask : a reference to 262144
property NSEvent : a reference to current application's NSEvent
set modifier_down to true
repeat while modifier_down
set modifier_flags to NSEvent's modifierFlags()
set option_down to ((modifier_flags div (get NSAlternateKeyMask)) mod 2) = 1
set shift_down to ((modifier_flags div (get NSShiftKeyMask)) mod 2) = 1
set control_down to ((modifier_flags div (get NSControlKeyMask)) mod 2) = 1
set modifier_down to option_down or shift_down or control_down
tell application "Waterfox"
activate
delay 0.05
set myName to get name of front window
if version > 72 and myName ends with " - Waterfox" then
if length of myName > 18 then
set myName to text 1 through -19 of myName
set myName to ""
set theUrl to ""
if version ≥ 87 then
set theUrl to get value of UI element 1 of combo box 1 of toolbar "Navigation" of first group of front window of application process "Waterfox"
return ("[" & myName & "](" & theUrl) & ")"
keystroke "l" using {command down}
keystroke (key code 53)
--keystroke "c" using {command down}
tell process "Waterfox"
click menu item "Copy" of menu "Edit" of menu bar 1
delay 0.05
set theClipboard to current application's NSPasteboard's generalPasteboard's stringForType:(current application's NSPasteboardTypeString)
return ("[" & myName & "](" & the theClipboard as string) & ")"
