[FIXED] Hook 2.0's "Energy Impact" (and CPU usage)
Hi,
I regularly check which applications are energy/battery hogs on my 2017 MBP. After I installed Hook 2.0 (I’m on 2.0.2) CPU usage while Hook is idle is about 8%, and the “Average Energy Impact” is on par with Dropbox. I have a “pro” dropbox account so I’m not surprised to see Dropbox up there, but the new Hook seems to be fairly power hungry… is this expected?
Really like the new UI though.
Best.
A performance update is in the works. See:
Thank you all, great to hear this issue is being addressed.
yep we fixed the problem on the week-end. We’re including some other fixes and will release ASAP. (I’ve updated the title of the topic to also include “CPU” usage.)
I can confirm 2.0.3 fixed this. thanks!
