To those users who utilize the deep linking feature with a PDF document stored in the cloud. I currently utilize both Citrix and PCloud apps on my mac and unfortunately I cannot get the deep linking feature to work with documents saved in either cloud based app. The deep link only opens the document but fails to take me to the page coordinates. It is my understanding from HookMark that Citrix is not supported.
My question is this. If you have successfully opened deep links from a cloud based app, which cloud based provider are you using and second, which PDF reader are you utilizing (i.e. skim, Adobe reader, nitro pro etc). Any feed back will be much appreciated.
