As I start using Hook more, I find that it is not very easy to integrate it in my workflow. There’s a quite a bit of a learning curve on the advanced features. Then it doesn’t work as smoothly either with DTP, EagleFiler, SharePoint or Outlook. These are apps where I find myself struggling and Hook didn’t work. I don’t want to learn scripting at this point of time. So I’m going back to manual method of creating links. I guess this purchase wasn’t meant for me
Thanks for giving Hook a try @ashish. We can’t dispute that Hook is at the beginning of the technology adoption life cycle, and that Crossing the Chasm is our objective.
May the Force be with you.
